Where is the intake air temperature sensor located?
109,000 MILES • 3.6L • 6 CYL • 2WD • AUTOMATIC
LARRY BROWN4
Trying to find intake air temperature sensor.
Mar 26, 2021 at 2:05 AM
I-SMOGEM
  • 118 POSTS
Hi Larry,
It is a component of the Mass Air Flow Sensor (MAF) as an integrated internal 'non replaceable' part.
Are you referring to the 'Ambient Air Temperature Sensor'?? It's under the front grille. Check this YouTube about it and it shows what's involved in getting to it to replace it:
https://www.youtube.com/watch?v=VyNXrTf2s7Y
Glenn
Mar 26, 2021 at 7:56 AM
LARRY BROWN4
Thank you very much sir.
Mar 26, 2021 at 10:43 AM
I-SMOGEM
  • 118 POSTS
My pleasure, and Thanks for the "Thanks". Doesn't actually happen that often. Be well and be safe.
Glenn
Mar 27, 2021 at 8:16 AM
