placement of brackets and mounts and components
100,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
TRACY DODD
I have just Installed a new engine in the truck listed above k1500 that was already apart. I need a blow up or diagram of how this front engine components go back together.
Mar 21, 2018 at 5:46 AM
STEVE W.
  • 15,418 POSTS
Once the front accessory mount is bolted on the rest of the components can only fit in certain locations and still get the belt to line up. I don't think I have ever seen an actual diagram for that. Normally you just unbolt the main mounting bolts and set components aside while you service or replace a part.
Try these two videos and see if they help -
www.youtube.com/watch?v=Lg0LxatJaKI
www.youtube.com/watch?v=AHkNHG_IqSM
Mar 22, 2018 at 12:48 PM
