pitman arm removal
163,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
RICHARD PAYAN
hi i just saw a video on how to remove the steering box on a 2002 tahoe and i want to know if u lossen up the steering box and disconnect all the lines before u use the puller to remove the the pitman arm or can i just use the puller with out disconnecting the lines or loosen the steering box thank you
Apr 1, 2016 at 1:55 PM
CAR-MAN145
  • 321 POSTS
I think you need to loosen the box to get enough room to use the tool if I remember right the frame is in the way
Apr 1, 2016 at 5:19 PM
RICHARD PAYAN
would i have to disconnect the lines even to just remove the pitman arm?
Apr 1, 2016 at 6:38 PM
CAR-MAN145
  • 321 POSTS
no just need to remove the bolts to be able to turn the box
Apr 1, 2016 at 8:16 PM
RICHARD PAYAN
thank you very much that helped alot!
Apr 2, 2016 at 7:37 AM
CAR-MAN145
  • 321 POSTS
You are welcome
Apr 2, 2016 at 3:25 PM
