Power windows will not roll up
98,000 MILES • 2.4L
WATERRSMUFF
I cannot get my windows to roll up. Does the polarity change on the window switches when it is working?
Aug 2, 2018 at 9:40 AM
  • 55,721 POSTS
Yes, the polarity changes when the switch is activated. Here is a guide that will show you how to test the switch:
https://www.2carpros.com/articles/electric-window-repair
Here is the power window wiring diagrams so you can see how the system works.
Check the fuses as well there is an integration relay as well.
Cheers, Ken
Aug 4, 2018 at 7:12 AM
