Pinout chart for PCM (P/N 3LA8-12A650-VA)
98,000 MILES • 3.0L • V6 • 4WD • AUTOMATIC
DMCMULLIN
  • 10 POSTS
I am trying to determine if there is an open circuit on the ground from HO2 sensor (bank1 sensor 1) to the PCM.
Nov 2, 2019 at 5:29 AM
DMCMULLIN
  • 10 POSTS
What I am looking for is a pinout chart to identify the correct pin connecting the ground from the harness connector for the HO2 sensor, bank1, sensor 1 to the PCM.
Nov 2, 2019 at 6:09 AM
Good afternoon,
I attached the diagram for the sensor. There is not external ground. The PCM is what controls the returns.
There is a power wire from the fuse box for the heater. The light blue/orange wire is the 12 volt feed.
Nov 2, 2019 at 6:35 AM
The rest of the diagrams.
Nov 2, 2019 at 6:41 AM
DMCMULLIN
  • 10 POSTS
this was very helpful, although what I was looking for was a pin diagram where the harness connection to the PCM is located so I can identify the pin no.26.
Nov 2, 2019 at 7:00 AM
Pin 26 is for the ignition coil, not the O2 sensor.
Can we start with the original issue and the code?
Nov 2, 2019 at 7:03 AM
DMCMULLIN
  • 10 POSTS
I am trying to determine if the ground (red/white wire) from the HO2-11 sensor to the PCM is an open circuit. To do this, I need to know where the pin location (or socket hole) on the harness is located. From your diagrams, I have determined the pin as no. 26.
Nov 2, 2019 at 7:22 AM
In the response with the 2 diagrams, The red/white wire goes to pin 93. It does not go to pin 26.
Nov 2, 2019 at 7:26 AM
DMCMULLIN
  • 10 POSTS
You are correct. The no. 26 must be at a junction. So, is there a chart showing the pin locations on either the harness connection or the PCM?
Nov 2, 2019 at 7:32 AM
All the pins are in the diagrams I sent you.
26 has nothing to do with your checks.
Nov 2, 2019 at 7:35 AM
DMCMULLIN
  • 10 POSTS
Can you help me physically locate pin no.93? I would be looking at either the harness (pin holes) or the PCM (pins)?
Nov 2, 2019 at 7:45 AM
Take a look at these.
Nov 2, 2019 at 8:00 AM
DMCMULLIN
  • 10 POSTS
Thank you very much. I assume "female" is looking at the PCM (pins).
Nov 2, 2019 at 8:08 AM
That is the harness side.
Nov 2, 2019 at 8:14 AM
DMCMULLIN
  • 10 POSTS
Thank you so much! You have been of the upmost help. Now I can make the test needed to determine whether the circuit is open or closed. My initial code was P0135 (heater circuit malfunction bank1, sensor 1). The sensor had been changed and the code kicked again after installation.
Thanks again, Doug
Nov 2, 2019 at 8:20 AM
You are welcome.
Nov 2, 2019 at 8:26 AM
DMCMULLIN
  • 10 POSTS
I have checked both the power side and ground side of the heater sensor. I have power but, no ground. I checked for continuity of the wire (red/white) from the sensor to the PCM and it is good. It seems that the PCM is not providing the ground. Does this mean that I need to replace the PCM?
Nov 5, 2019 at 12:50 AM
That is exactly what it sounds like.
Nov 5, 2019 at 12:57 AM
DMCMULLIN
  • 10 POSTS
Is this a common issue?
Nov 5, 2019 at 1:00 AM
Yes, in some cars. Not all but some. Each one is different.
Nov 5, 2019 at 1:07 AM
