Wire set-replaced,EGR valve-replaced, fuel pump-replaced and the vacuum lines checked. Still pings! What is the part that regulates the fuel flow to
the injectors and where is it located? Or what else could it be?
Also, the compression is fine.
Nov 21, 2016 at 4:37 PM
