Pinging
1996 FORD BRONCO
100,000 MILES
ALUPINYA
When driving the motor pings under the least of load, check timing , no vacuum leaks , not real sure what it the problem is . I thought about buying new MAP sensor but when I went to get one, it looks a lot different than the one on the truck now. Any help would be great , thank you for your time and help.
May 17, 2013 at 6:04 AM
  • 31,937 POSTS
If it has just started may be a bad batch of fuel, are there any set fault codes? check regardless if no check light is on.
May 17, 2013 at 9:44 AM
ALUPINYA
Thanks mhpautos, Its been going on for a while now, no fault codes , I have disconnected battery to reset the PCM and it still pings.. 91 octane , any Ideas.
May 17, 2013 at 1:25 PM
  • 31,937 POSTS
Normally a carbon build up problem or a timing problem, you may need to see if the distributor advance is working.
May 18, 2013 at 8:12 AM
