Pin Position on a NV233 transfer case?
4.7L • 4WD • AUTOMATIC
LAZARO RUIZ
I removed the coupler on the transfercase to in stall a new shift motor. After I installed the new one I no longer had forward or reverse in the truck from the transmission and thier was a grinding sound going into park. So I looked up the transmission pin selector position for it. It says to go all the way to the right one click back but that is not allowing the shaft to move freely and when I do. But going all the way left and one click back it moves freely but that is not the specific position as the standards said. So im not sure if thats neutral or 2HD and also how do I get the transfer case motor to go to that position before reinstall?
Nov 29, 2026 at 6:03 PM
