Pin code, intermittently not starting horn blowing?
78,000 MILES • 2.7L • V6 • 2WD • AUTOMATIC
WILLIAM927
I have a lunch 431v can’t find out can't find out how to get the pin code can’t find out how to get the pin code.
Jun 23, 2023 at 7:30 AM
WILLIAM927
It started by intermittently not starting horn blowing. I reset everything and after a month or so it’s doing it again turned over won’t start then I go in and hit the reset then it doesn’t start or anything. I did erase the old keys hope because whenever I got done, I was hoping it would lead me to the pin code, but it didn’t. But it didn't.
Jun 23, 2023 at 7:39 AM
STEVE W.
  • 15,410 POSTS
If you mean the security system PIN, the Launch cannot retrieve it. The dealers can get it and some locksmiths can. There are tools that can retrieve the PIN, but they are not commonly available. There is supposedly an app out there that can be installed on some Launch units that can retrieve the PIN, but I've heard it sometimes works and sometimes breaks the system.
Jun 23, 2023 at 8:00 AM
