Pickup just out of the blue started running rough. Was still able to drive it.
1991 FORD F-150
17,000 MILES • 5.0L • V8 • 4WD • AUTOMATIC
SMITTY514
Pickup started running rough. Can start the pickup just fine. Will only run if I pump the foot feed. Replaced Throttle position sensor, plugs, wires, rotor, distributor cap, and fuel filter. and ECM. Still doing the same thing. The next thing I was thinking about was the idle control valve. I switched tanks to try and rule out fuel pump. Still had problem after doing this. Could it possible be Fuel injectors causing my problem? Can you help me? Thanks
Oct 13, 2015 at 1:20 AM
CJ MEDEVAC
  • 11,004 POSTS
PLEASE SEE MY LINK BELOW
http://www.2carpros.com/questions/2005-ford-escape-rough-idle-at-low-rpm
I'VE SEEN THE "THE LITTLE SMACK" THING WORK SEVERAL TIMES, IN WHICH THE IDLE DID, AT LEAST FOR A MOMENT, STRAIGHTEN UP TO VERIFY THAT THE IAC WAS THE ISSUE. IF YOU TRY TO CLEAN IT AND THE HOLE IT'S OVER, USE THROTTLE BODY CLEANER.
RETURN WITH GOOD NEWS
THE MEDIC
Oct 13, 2015 at 10:29 AM
SMITTY514
What about the fuel injectors. Could this be the problem?
Oct 15, 2015 at 1:26 AM
CJ MEDEVAC
  • 11,004 POSTS
THAT IS A POSSIBILITY
HOW 'BOUT THE CHECK ENGINE LIGHT ON AND SEEING IF YOU HAVE ANY CODES?
SCANNER CONNECTIONS ARE MOST LIKELY ON THE DRIVER'S SIDE FENDER, NEAR THE FIREWALL
CHECK THIS OUT, IT 'LL SHOW YOU HOW, ONCE THERE, SCROLL DOWN PAST THE ICONS
http://www.icheckengine.com/2012/05/ford-obd1-codes.html
WHICH SIDE OF THE U.S. ARE YOU ON?
DID YOU "SMACK" THE IAC OR ATTEMPT TO CLEAN IT? THIS IS A COMMON ITEM TO MESS UP AND EZ TO DO.
THE MEDIC
Oct 15, 2015 at 10:04 AM
