pick up problem at altitude
120,000 MILES • 1.3L • 4 CYL • 2WD • MANUAL
LBZN DELEX
no pickup at altitudes above 15,000 feet.
It does good at plains, but not in the mountains even if i push it hard, nothing in the result.
what could be the problem?
May 8, 2016 at 2:22 AM
HMAC300
  • 48,601 POSTS
the height and lack of air for one, check your map sensor and see if any vacuum lines if any are soft and sucking together.
May 8, 2016 at 2:54 AM
LBZN DELEX
it is fine i checked. Any other suggestions?
May 8, 2016 at 3:11 PM
  • 55,781 POSTS
Cars have low power at altitude because of the lack of air, if no check engine light is on and the vacuum hoses are okay that's how it will run.
Best, Ken
May 11, 2016 at 11:01 AM
