Start it in the morning, for two seconds she sounds like a diesel
150,000 MILES • 4 CYL • 2WD • AUTOMATIC
NASER NASER
  • 836 POSTS
Read some online and it pinpoints to the phasers. what do these phasers do and when they fail like they do why do they sound like that? how do i ensure the phasers are what are causing this noise? instructions on replacing them? no check engine light, no other issues, drives smooth.
Aug 15, 2019 at 10:38 PM
NASER NASER
  • 836 POSTS
correction: there is a code p001762, but no check engine light.
Aug 15, 2019 at 11:41 PM
  • 110,248 POSTS
Welcome to 2CarPros.
A cam phaser is designed to allow the computer to control valve timing. On your vehicle, they are referred to as cam adjusters. To replace these is very involved and yes they can make a chattering sound. I attached a picture and circled the parts you questioned.
I will also tell you there is a technical service bulletin (TSB) regarding start up noise from the timing chain area which I believe what you have. The test to identify the source requires a special program/computer scanner.
Here is the TSB
2013 Mercedes Benz C 250 Sedan (204.047) L4-1.8L Turbo (271.860)
Engine noises (rattling) after engine start
Vehicle Engine, Cooling and Exhaust Engine Timing Components Timing Chain Technical Service Bulletins Engine noises (rattling) after engine start
ENGINE NOISES (RATTLING) AFTER ENGINE START
- Engine noises (rattling) after engine start -
Topic number
LI05.10-P-058758
Version
3
Design group
05.10 Timing chain drive, toothed belt drive
Date
12-07-2016
Validity
ENGINE 271.8 EVO
Reason for change
Amended step 3 instructions of "Remedy" field.
Complaint
Noise:
A rattling noise may be heard from the area of the chain drive for approx. 2-5 seconds after engine start.
Cause
The noise can have various root causes. Refer to Remedy to perform diagnosis / repairs.
Remedy
Xentry Diagnostics provides a guided test for systematic troubleshooting:
1. Connect XENTRY/DAS
2. Work through the guided test. To do this, call up menu item "Control unit view – Type of drive - ME motor electronics - Tests - Check chain drive and engine oil level.".
3. Perform repair according to findings and WIS AR documents in DG05.
Symptoms
Symptom
Power generation / Engine noise / Chattering
Power generation / Engine noise / Clanking
Power generation / Engine noise / Rattling
Power generation / Engine noise / Clattering
Power generation / Engine noise / Pounding
Power generation / Engine management / Indicator lamp / Engine diagnosis / lit
______________________________
Let me know if this helps answer your question and if the TSB seems to match the symptoms.
Aug 16, 2019 at 2:30 PM
NASER NASER
  • 836 POSTS
Yes, i read similar stuff online, yes rattling 2-3 seconds, oil level is full. I can change anything as far as there are instructions.
Aug 16, 2019 at 11:50 PM
  • 110,248 POSTS
Welcome back:
First, you need to confirm that is the issue and determine which one it is. Do you have access to the scan tool mentioned in the aforementioned link? Let me know. I can provide directions for chain replacement and actuator if it is determined that is the issue. It's a lot of work and I would hate to see you do it and have the same problem.
Aug 17, 2019 at 9:57 AM
NASER NASER
  • 836 POSTS
Ya, i have a scanner.
Aug 17, 2019 at 11:46 AM
  • 110,248 POSTS
Is the scanner configured for Xentry? That is Mercedes software? If it is, then you need to hook it up and follow the directions listed in my first post.
Let me know if I can help.
Aug 17, 2019 at 12:00 PM
