Pffft sound and momentary interuption in acceleration when running air conditioner
259,000 MILES • 2.0L • 4 CYL • AWD • MANUAL
BRIANTHECURIOUS
My vehicle operates normally when I am not using the air conditioner; however, when I turn on the AC I will occasionally hear a *Pfffft sound and experience a momentary loss in acceleration. It feels like a timing/valve issue, but I cannot understand why it would only occur when I use the AC. Of course, I am new to the world of auto mechanic stuff so I really do not know what I am talking about. Can someone educate me? :-)
Apr 13, 2016 at 6:00 AM
CJ MEDEVAC
  • 11,000 POSTS
THIS SOUNDS LIKE THE AIR CONDITIONER CLUTCH ENGAGING
THIS MEANS THAT THE AIR CONDITIONER COMPRESSOR (WHICH IS NOT TURNING AT ALL) SUDDENLY "HOOKS UP WITH" THE FAST TURNING AIR CONDITIONER CLUTCH PULLEY WHEN IT IS CALLED ON TO DO SO.
USUALLY THERE IS NO NOTICEABLE DRAG DOWN IN ENGINE POWER, ESPECIALLY ON BIGGER ENGINES (THOUGH YOU STILL HEAR THE NOISE!)
IF IT REALLY SEEMS EXCESSIVE (IF YOU'RE LIKE ME, YOU ARE REALLY "TUNED INTO" THIS OCCURRENCE), HAVE AN AUTOMOTIVE AIR CONDITIONER PROFESSIONAL CHECK ITS OPERATION.
ALSO CONSIDER THE SMALL ENGINE SIZE, THE LOADS YOU ARE MOVING, TERRAIN AND THE LAST TUNE-UP.
MOST VEHICLES NOW-A-DAYS USE "A/C COMPRESSOR (EVAPORATOR)" TO REMOVE MOISTURE FROM THE AIR IN ANY HEAT SETTING THAT USES "DEFROST". MORAL OF THE STORY: THE A/C CLUTCH MAY BE HEARD ENGAGING WHILE IN A DEFROST MODE
THE MEDIC
Apr 13, 2016 at 11:59 AM
BRIANTHECURIOUS
Thank you for your response, CJ Medevac!
This makes sense about the air conditioner compressor/clutch engagement. I should also clarify that it does not just occur when I flip on the air conditioner. It continues to occur periodically while I am driving and seems to continue for up to the first twenty to thirty minutes that I have the air conditioner turned on. The *pffft sound and engine disruption seem the most pronounced under harder acceleration or when I am about to shift gears. Does that alter your diagnosis in any way?
Again thank you for your response. I appreciate it!
Brian
Apr 14, 2016 at 4:01 AM
  • 55,808 POSTS
Happy to help use 2Carpros anytime!
Apr 17, 2016 at 11:57 AM
CJ MEDEVAC
  • 11,000 POSTS
JUST SAW YOU
SOMEHOW MISSED THE NOTIFICATION/ CLICKED ON IT/ OVERLOOKED IT
WHEN YOU TURN ON THE A/C OR DEFROST
THE SYSTEM "TURNS ON"
THE COMPRESSOR ENGAGES UNTIL IT "GETS SATISFIED", THEN IT STOPS COMPRESSIN' OR RATHER THE CLUTCH TURNS OFF
WHEN IT SENSES THE NEED TO COME BACK ON, IT DOES!
DEPENDING ON THE "CHARGE" IN THE SYSTEM IT MAY ENGAGE MORE OR LESS OFTEN
ALL OF THIS HAPPENING WITH THE SYSTEM TURNED "ON"
MY A/C IS KINDA SORTA AMBIENT AIR TEMP DEPENDENT, SEE MY PIC BELOW
THE MEDIC
Apr 20, 2016 at 9:19 AM
