Noisy
2005 PEUGEOT PARTNER
96,000 MILES • 4 CYL • 2WD • MANUAL
STEVE TATE
my van seems louder, engine makes more noise and the management light is on, a mechanic has had a diagnostic done on it and cant find a problem any ideas?
Apr 21, 2009 at 8:12 PM
SQM
  • 6,383 POSTS
One thing to keep in mind that as components ages and gets worn, they can make more noise. Which is part of normal wear and tear.
However, if you have unusual noises it needs to be diagnosed and repaired.
Take a look at this guide, it covers the typical engine noise issues:
https://www.2carpros.com/articles/engine-noises
Go through this and let me know what you find or if you have any questions.
You mentioned that the management light is on. Is that the service engine light you are refereeing to?
If the check engine light is illuminated, a good first step would be to scan and retrieve the error codes. As that can help with the diagnostics.
Here is a helpful article:
Let me know of any questions.
Nov 14, 2021 at 9:43 AM
