1997 Other Peugeot Models Ignition problem
1997 PEUGEOT
KHEMICA
1997 Other Peugeot Models Manual
hello
I have a Pug 306 Diesel.
In the mornings, when the engine is cold, I turn on the ignition and it turns over for ages. At first, the ignition is slow, but the more I turn it over, it gets faster and a little smoke starts to come out of the exhaust. This does not seem to drain the battery when I keep turning it over, although, it usually takes me about 2 minutes of me doing it before it finally starts up. Then, as it finally starts up, a huge cloud of black smelly smoke comes out of the exhaust!.
This has got gradually worse over time, and now it is not just in the mornings when the engine is cold that it is happening. It happens most of the times that I use it now.
Thank you for your time to read this and I look forward to a reply if you are able to help in any way.
Sep 13, 2008 at 2:42 AM
DAVE H
  • 13,384 POSTS
sounds like the heater plugs are ready for a change
Nov 7, 2008 at 7:00 AM
