1994 Other Peugeot Models
1994 PEUGEOT
212,000 MILES • 4 CYL • FWD • MANUAL
JMURRAY01
Hi, Ive got a Peugeot 405 and here is the questions - When it is around 0degrees c out side the brakes hardly work at all. It is like there is a film of ice on the disk. Also, after about 20-25 miles there is a strong smell of diesel and hesitates to start when cold. Takes 2-3 separate cranks of 5 seconds. If you have any help on any of the questions please reply.
Jan 3, 2009 at 1:00 AM
DAVE H
  • 13,383 POSTS
replace brake pads and shoes .. replace the battery and fuel filter .. also add a good fuel injector cleaner to the tank
Mar 14, 2010 at 10:28 AM
JMURRAY01
Thanks for the reply.
It's fine now. Still takes a little longer to start than usual but is much better.
It has new brakes (everything, even down to the lines!) now and a new battery (though that was not the problem at the time). Oh and clean injectors.
Mar 14, 2010 at 11:11 PM
