1990 Other Peugeot Models windows
1990 PEUGEOT
HINDI
Electrical problem
1990 Other Peugeot Models 4 cyl Two Wheel Drive Manual
can i wind up electric windows manually i think the circuit has blown
Oct 2, 2008 at 7:17 AM
DAVE H
  • 13,384 POSTS
check fuses and switches .. add 12 volts directly to the motor with a ground/earth to see if the motor runs .. if not the motor is the fault .. you will have to get the window up by hand ..after releasig it from the motor ..
Mar 15, 2009 at 12:07 AM
