1999 Peugeot Expert Heating Not Working
ANTANDVIX
Heater problem
1999 Peugeot Expert Two Wheel Drive Manual
Hi can you help, the heating in my peugeot expert has decided to die, it worked on and off and flashing the main beams made it kick in very strange, but now the fan wont start at all, ive checked fuses in the main fuse box in engine bay and have removed front panel where heating controls are and there is no power to any of this when checking the connections feeding the removable circuit board is there possibly any fuses i havent found or a relay that turns this on and off with the ignition switch? Any clues would be great
Many Thanks Antony
Jan 20, 2009 at 1:20 AM
DAVE H
  • 13,383 POSTS
we do not have the spec's for this vehicle .. there may be a relay in the under bonnet fuse box .. your local library should be able to supply a repair manual for the vehicle .. or an autoparts store !
Mar 12, 2009 at 2:28 PM
