alternator replacement
2007 PEUGEOT 807
108,000 MILES • 4 CYL • 2WD • MANUAL
KMEDCALF
how to remove alternator the fit a new alternator
Sep 2, 2010 at 5:19 AM
  • 54,840 POSTS
You must start by disconnecting the battery to avoid a short circuit. then remove the drive belt.
Here is a guide that will give you an idea of what you are in for when doing the job.
https://www.2carpros.com/articles/how-to-replace-an-alternator
you should test it once it is installed.
Cheers, Ken
Jan 16, 2018 at 11:06 AM
