Engine immobilizer fault
CRUZIN
Four cylinder manual 60,000 miles.
Hi there,
I have owned this car listed above (2.0 HDI S) for a short time but the problems i am having are enough to last a lifetime.
The most recent (currently the only) fault is that the vehicle will not start and it shows an error 'engine immobilizer fault'. please could someone tell me what this could be and how this could be fixed?
I would be greatfull if this could be resolved and i am happy to donate once i have recieved a reply.
Many Thanks
Sam
Feb 13, 2009 at 6:50 AM
DAVE H
  • 13,383 POSTS
the vehicle needs to be plugged into a diagnostic computer to locate the exact cause of the fault and to reprogram the cars computer.
Mar 12, 2009 at 2:20 PM
VAZZ
Here is how you can reset the immobilizer. It is kind of tricky, but trust me it works. Do like this:
- Disconnect the battery for at least fifteen minutes.
- When you are about to re-connect the battery, leave the drivers door open and have the car key outside of the engine starter.
- When the battery is on again, close the drivers door and turn the key to light up the instrument panel but do not start the engine yet.
- Open the drivers door and take away the key.
- Close the drivers door and start your engine.
Your problem is now solved!
The most common solution for this problem is to change the battery in the car-key, so the immobilizer is easer to "read" it.
Hope that helps!
Sep 13, 2009 at 2:43 AM
HUMPH7EY
It worked for me. Thank you so much.
May 9, 2012 at 6:44 AM
CARSV
Thanks vazz. It worked for me too.
Jul 13, 2012 at 7:09 AM
ANONYMOUS
  • 0 POST
Thank you so much from Belarus! It worked for my peugeot 807 2.2 HDI 2003!
May 21, 2013 at 11:15 PM
FABMANN
Please , i own the same Peugeot 807 2.2 HDI 2005 model, the car was driving and suddenly stopped.it never starts again when i open ignition to step two the dashboard light comes up when i try to start it never starts but keeps revolving and runs the battery down. i called for diagnose which was done three times now and each time it comes up with different error codes, such as listed below. please i will be glad for any help on how to sort this issue this is getting to be three months now .
Fault >
Description
Status
P0340
Crankshaft synchronizing
No camshaft sensor signal
Permanent fault
P1435
Additive system fuel filler
Cappresent sensor fault
Permanent fault
P0110
Inlet air temperature signal
Short circuit to positive or
Open circuit
Permanent fault
P0571
Brake switch communication problem
Permanent fault
read trouble code
Fault
Description
Status
P0020
Intake variable cam timing solenoid short or open circuit bank 2
Faulty wiring and connections faulty camshaft profile control solenoid
read current trouble code
Jan 6, 2016 at 4:14 PM
FABMANN
Also, recent i called a Peugeot mechanic after doing the diagnose he said the problem is from the com 2000, have anyone had such an issue before or have to replace com 2000 before? please help we need this car urgently.
Jan 6, 2016 at 4:16 PM
