peugeot 508
2013 PEUGEOT
26,226 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
MEHDI_SHARIATI
Engine coolant temperature problem, The water temperature is normal, but in cluster fluctuates ecu?
Apr 3, 2016 at 1:51 AM
  • 55,682 POSTS
This sounds like a problem with the coolant sensor, this will make the temp gauge act erratic.
Best, Ken
Apr 23, 2016 at 1:30 AM
MEHDI_SHARIATI
but.temp coolant in diag is normal
Apr 23, 2016 at 3:17 PM
  • 55,682 POSTS
Okay, if in diagnostics its normal then the gauge itself must be bad. I don't think its the computer because they rarely go bad, its more likely the gauge.
Apr 24, 2016 at 12:41 AM
MEHDI_SHARIATI
Electric thermostat temperature is -40
Apr 26, 2016 at 4:16 AM
HMAC300
  • 48,601 POSTS
we have no info on how to check this car as it's not in USA have the sensor and gauges checked.
Apr 26, 2016 at 6:15 AM
