1984 Peugeot 505 PROBLEM STARTING WHEN ENGINE IS ALLREADY W
1984 PEUGEOT 505
250,000 MILES • 4 CYL • 2WD • MANUAL
ARMANDO LEON
505 STI. IT HAS FUEL INJECTION (K JETTRONICS). THE CAR HAS A PROBLEM STARTING AFTER IT HAS RUN FOR MORE THAN 30 MINUTES AND THEN SITS WITH ENGINE TURNED OFF FOR ANOTHER 40 MINUTES. IT STARTS VERY WELL WHEN COLD.
I CHANGED THE WARM-UP PRESSURE REGULATOR BUT THE PROBLEM CONTINUES.
Sep 8, 2009 at 6:15 AM
P505
Hey I have a 1984 Peugeot SR,it had problems with power,bad shuddering including starting problems when hot.Turns out it was just the points in the distributor that were finished,MaN what a difference it made!please check it out Asap
Feb 17, 2012 at 12:54 PM
