2007 Peugeot 407 p0341 camshaft position
2007 PEUGEOT 407
WAHEEB48
Electrical problem
2007 Peugeot 407 4 cyl Front Wheel Drive Automatic
hii all
p0341 camshaft position sensor a circuit range performance bank 1 or signle sensor
to replace the sensor or to cheke the timing belt
i dont have the diagnos steps
the car some time not start
Apr 15, 2009 at 6:11 PM
BLUELIGHTNIN6
  • 16,542 POSTS
First inspect wiring to sensor to ensure it is clean and tightened properly. If electrical connections are OK, suspect faulty sensor
Thanks for using 2CarPros.com!
Apr 15, 2009 at 6:15 PM
WAHEEB48
i dont have the sensor wiring diagram steps
Apr 15, 2009 at 6:24 PM
WAHEEB48
How do I check the sensor itself
And what providers need to reach sensor voltage
5V??
Apr 15, 2009 at 6:32 PM
BLUELIGHTNIN6
  • 16,542 POSTS
unfortunately I do not have access to any information for this type of vehicle. however perhaps a call to local dealer can provide you with the wiring diagram you need in order to inspect the wiring to sensor. in the mean time, i will ask around to my fellow technicians here at 2CarPros to see if any of them have access to Peugeot information.
Apr 16, 2009 at 11:58 AM
