2002 Peugeot 406 Air in coolant
2002 PEUGEOT 406
118,000 MILES • 4 CYL • FWD • MANUAL
SPINNER153
I have had to top up my coolant twice in 3 weeks. On closer inspection, the coolant is being forced out of the cap of the expansion tank (which is firmly screwed on, seal in tact). After the engine is run, I have bled to system a couple of times and each time there is air in the system. I have check for leaks, checked the exhaust of excess moisture. What could be causing this?
Engine is a 2.0L HDi (90Bhp)
Engine temperature is good, stayign at 90C even under stress, and thermostat is operating correctly (opening radiator loop @ 90C).
Dec 17, 2009 at 1:51 AM
DAVE H
  • 13,384 POSTS
have a cylinder compression test to check for headgasket failure
Mar 30, 2010 at 9:23 PM
