2001 Peugeot 406 fuel delivery system
2001 PEUGEOT 406
200,000 MILES • 4 CYL • FWD • MANUAL
SRAMEDI
the most left fuel injector has no pulse signal just only one pulse when engine starting and then that pulse signal stops.
the most right fuel injector has "continuos" pulse signal (i.e. there is no discrete signal).
the other two fuel injectors are working fine.
for that my car has a small movement power and your answer would be appreciated.
Note: I have replaced the two injectors but the problem is same.
Thank you in advance.
Nov 4, 2009 at 12:58 AM
DAVE H
  • 13,384 POSTS
check/clean or replace the cam and crank sensors .. also check the wiring to the injectors
Mar 30, 2010 at 9:19 PM
