the most left fuel injector has no pulse signal just only one pulse when engine starting and then that pulse signal stops.
the most right fuel injector has "continuos" pulse signal (i.e. there is no discrete signal).
the other two fuel injectors are working fine.
for that my car has a small movement power and your answer would be appreciated.
Note: I have replaced the two injectors but the problem is same.
Thank you in advance.
Nov 4, 2009 at 12:58 AM
