2007 Peugeot 405 high idel speed
SAEED PARYANI
Engine Mechanical problem
2007 Peugeot 405 4 cyl Two Wheel Drive Manual 6000km miles
Dear Sir
when engine is working and car is stopped the idel speed is 900RPM, but when the is moving and the gear is in neutral position(the wheel is rotating) the idel speed is 1200 rpm.pls tell where is the fault and
how we may have the 900RPM in this condition.IN traffic condition this fault is bothering too much
thanks[img:68df37942c]http://www.2carpros.com/forum/automotive_pictures/345506_15990_1.jpg[/img:68df37942c]
Apr 17, 2009 at 11:08 PM
  • 75,988 POSTS
Too fast an idle speed. If an engine without computerized idle speed control is idling too fast and refuses to come down to a normal idle speed despite your best efforts to back off the carburetor idle speed screw or air bypass adjustment screw (fuel injection), air is getting past the throttle somewhere. Common leak paths include the carburetor and throttle body gaskets, carburetor insulator spacers, intake manifold gaskets, and of course, any of the engine's vacuum fittings, hoses and accessories. It is even possible that leaky O-rings around the fuel injectors are allowing air to leak past the seals. Another overlooked item can be a worn throttle shaft and a defective idle speed speed control motor/valve stuck in the extended (high idle speed) position/throttle position sensor. Also the throttle plate could be binding in its bore and kinked accelerator cable, coolant temperature sensor might not be operating properly misleading the computer that the engine is still cold and computer throwing fuel at it raising the idle speed.
Apr 17, 2009 at 11:22 PM
