1998 Peugeot 405 Engine hesitates on acceleration
SAFASAVAFI
Engine Performance problem
1998 Peugeot 405 4 cyl Front Wheel Drive Manual
hi
my Engine's car is hesitates on acceleration.specially in low (heavy gear).some time its temperature go to 90C and go back to 70C. i change clutch kit,fix carburator and change air filter and sparks and timing belt .but it never go over 100 KM/h. it semms very dificult to move in gear No1 (from stop state).i dont know what must do?! please help.
Feb 28, 2009 at 3:58 AM
DAVE H
  • 13,383 POSTS
start by having a compression test of cylinders and check fuel pressure !
Mar 14, 2010 at 10:40 AM
ROCKAKO
Hi.your car may have serious problems with engine and gear box. maybe your engine pistons have damaged that couse you some hicups and some gears in your gearbox had corrosion.
Sep 28, 2012 at 11:17 PM
