Problem with the transmission
I wander if you gays can help me !
I have the Peugeot 307 automatic 80KW, the symptoms that this automatic transmission have is that every 6000-8000km needs an oil change ! if you not do that the automatic gear computer gives an error and in the display you see ** Automatic transmission gear fault** . Then you have only the 3gear to drive until you make a reset ! when I make an oil change, the oil cams out a little brown but it seems to me that it is not new but still useful ! I notice that after 8000km the automatic transmission sleeps at the morning and then came the error code !!! But if I change the oil everything is ok !! If the oil was chip it is for me no problem but 2 liters cost 25 euro. I ve been to the Peugeot and the tell me to change some valves but for me it not seems that this is a problem of the valves, if it where so the transmission would make other serious problems ! peugeot in france say it is sealed for life J !!! I am waiting for you technical answer ! PS the transmission oil is ESSO 4HP20
Mar 7, 2010 at 8:53 PM
