I have a 1.6 Rapier model (I have no idea what 4 cyl meant sorry). It was in for a recall on the ABS a few months ago, something to do with water ingress). Well ever since then I have the following problems:
The ABS fault light comes on and off randomly. It isn't speed dependant, sometimes it's as soon as I start the engine. Then when I brake it make these awful rumbly noises like something is hitting my foot under the brake pedal. Again, this randomly happens, occasionally it doesn't do it. The garage told me its a O/S/Rear Sensor Fault but not sure and don't know how to fix it for sure. I have researched on the internet and it seems every Peugeot owner has the exact same problem. All have complained back to Peugeot stating it was after their recall had been done but Peugeot are insisting it's not related to the recall. I do not believe this coincidence! Anyway, is there anything you can suggest as I really can't afford all the replacement parts they're suggesting especially when they're not sure that it'll work. Many thanks for your help in advance! Vicky
Jan 26, 2010 at 1:34 AM
