2003 Peugeot 307 MIL CODES
140 MILES • 4 CYL • 2WD • MANUAL
BABYMAC
Hi I wonder if you can help? I have a peugeot 307 diesel which has been in and out of peugeot garage for them to try and sort it out engine code light keeps coming on. the egr valve has been replaced but still get fault code p0400 and also ignition code p1352. \they replaced the glow plug relay.I have looked at other response's to this and will start with the vacume hose on egr valve. any other advice would be greatly apprecaited. thanks James
Dec 2, 2008 at 1:26 AM
DAVE H
  • 13,383 POSTS
have them check the wiring to the sensors and the wiring connector at PCM for damage/wear etc.
Mar 12, 2009 at 2:09 PM
