central locking has failed?
2002 PEUGEOT 307
MADIESDADDY
central locking has failed i can hear all the door motors working but can only enter my car through the drivers door and boot had this problem for about 3 weeks now when i try the door handles from inside or outside the car i feel no resistance on the handles also all 3 doors went at the same time any ideas
Dec 9, 2008 at 10:52 PM
SQM
  • 6,383 POSTS
This type of issues many times can be solved by resetting the central locking system.
Try this procedure:
Put the key in the ignition, turn to the on position (do not start).
Then you will have to wait for minimum of 10 seconds.
Then press and hold the lock button for several seconds.
Turn the key to the off position and remove the key.
Then you will have to wait for another 10 seconds. Then press the lock button once.
This should reset the locking system.
https://www.youtube.com/c/2carpros/featured
Sep 21, 2021 at 2:23 AM
