2001 Peugeot 306 noice
JAMES09
Engine Mechanical problem
2001 Peugeot 306 6 cyl Front Wheel Drive Automatic
hi, the engine light wont go off and not sure what the poblem is? and dont want to drive the car
Aug 25, 2010 at 10:54 PM
  • 31,937 POSTS
Hi there,
This is a visual warning that there is a set fault code that needs to be investigated, you can drive the car, this should not be a problem, if the problem is some what sever it will go to limp mode, go see your local dealer and get a diagnostic scan done, this will tell them the actual code and with this they can repair what is required.
mark (mhpautos)
Aug 25, 2010 at 11:43 PM
