1998 Peugeot 306 engine
CLOUGH 666
Engine Performance problem
1998 Peugeot 306 Four Wheel Drive Manual 64000 miles
car is perfect well all most, my car starts up, then after few minutes, it cuts out, had my car put on diagnosis machine and said its idle valve , i take the wire out of the idle valve and its ok, but then im using 2 much petrol. ive tried putting other idle valves in but keeps cutting out
Oct 19, 2009 at 5:08 AM
DAVE H
  • 13,383 POSTS
repalce the Idle valve .. replace air filter and check/clean MAF sensor
Mar 14, 2010 at 4:03 AM
