1997 Peugeot 306 Will not start.
BIGANT92
Electrical problem
1997 Peugeot 306 Front Wheel Drive Manual 70000 miles
Hi, can anybody help me?
My car has recently stopped responding to the turning of the key to start the motor. I have reason to believe that there is something wrong with the ignition as it just will start not when the key is turned.
Are there any ideas or tips that I could follow to get it back on the road?
Oct 11, 2010 at 5:27 AM
DAVE H
  • 13,383 POSTS
Check you have power at the starter motor with someone turning the key to start .. if you have power the starter motor is bad ..if you have no power check relay, fuse then ignition switch
Nov 14, 2010 at 12:00 PM
