1997 Peugeot 306 Fumes in cabin
1997 PEUGEOT 306
SCOTTIE12345
Engine Mechanical problem
1997 Peugeot 306 Front Wheel Drive Manual 135000 miles
I have a Peugeot 306 Turbo Diesel 135,000 miles R reg.
There is an issue of fumes coming into the car when driving. It does not start straight away, gets bad after about 20minutes. Fumes are bad when driving under 30mph and in slow traffic.
There is a very small oil leak behind the engine, couple of drips on ground after about 2 – 3 days. The engine cover under the car has oil mixed with general dirt and has not dried out.
Also when starting the car cold after a week of being stationery there is a small amount of fumes/smoke that comes out of the bonnet. Nothing excessive and goes away after about 5 seconds.
Car runs fine and does not use an excessive amount of water. No excessive smoke or drips out of the exhaust when driving. Recently I have had the air filter and oil filter changed.
I am getting the whole exhaust replaced as the end of the tail pipe has corroded and there is not a proper exhaust exit and I think this could be the cause of fumes coming into the cabin.
I have asked if replacing the exhaust will stop fumes coming into the cabin but have not got a straight answer and they said it could also be the oil leak which at best could be the Rocker or at worst the Head Gasket.
What is the best way to solve as I cannot get a straight answer from the mechanic.
Oct 12, 2010 at 7:01 AM
  • 31,937 POSTS
Hi there,
Any exhaust leak under the car will be drawn into the cabin as a result for the partial vacuum created, with the exhaust sealed and the tail pipe clear of the rear of the car, this is the best way to stop any fumes entering the car, also if the out side air vent is open, any burning oil from a leak on a hot engine may also enter the cabin, get the oil leak attended to as well, start here.
Mark (mhpautos)
Oct 13, 2010 at 6:02 AM
SCOTTIE12345
cracking thanks will make a start. Cheers
Oct 13, 2010 at 3:56 PM
  • 31,937 POSTS
Let me know how you get on, there are a few finer points we can look at as well if needed.
Mark (mhpautos)
Oct 13, 2010 at 4:07 PM
