2010 Peugeot 207 turbo fails some time and depollution syst
2010 PEUGEOT 207
25,000 MILES • 4 CYL • FWD • MANUAL
PAVAN267
I checked the vacuum lines,vacuum resorvoir and vacuum pump,found to be ok,i checked the mechnically wastegate valve,found to be ok,even i checked the electro solenoid valves,found to be ok,no leaks found from wastegate to vacuum pump.
Dec 19, 2009 at 4:13 AM
DAVE H
  • 13,384 POSTS
Did you have a question ?
https://images.2carpros.com/forum/automotive_pictures/266999_2carxmas2_8.jpg
Dec 22, 2009 at 8:22 PM
