2008 Peugeot 207 problem P2263
GR13
Engine Performance problem
2008 Peugeot 207 4 cylinder Front Wheel Drive Manual 29,825 miles
P2263 :Turbo/super charger boost system:Performance
I have this problem in the car recently, I do very often. Why?
When you pull out this problem after the car is not raising pressure. Logic comes into the safe mode and works only with the turbo vacuum.Why?
Please help if you know.
Thanks
Jun 28, 2010 at 7:50 PM
  • 55,616 POSTS
Hi GR13,
It looks like the turbo is having a problem does the engine have enough power when you drive it? If the bearings go out in the super charger, If this seems okay the EGR system needs to be de-carboned this should fix the problem.
Let me know who it goes
Apr 29, 2016 at 5:17 AM
