2003 Peugeot 206 IDLE ADJUSTMENT
2003 PEUGEOT 206
49,480 MILES • 6 CYL • FWD • MANUAL
AZMA
  • 11 POSTS
DEAR SIR
KINDLY ADVISE HOW IS THE IDLE ADJUSTED ON A PEUGEOT 206 X LINE. IS THERE A PART THAT NEEDS TO BE REPLACED. ADJUSTING THE THROTTLE DOES NOT RESOLVE THE IDLE.
THE IDLE NEEDLE MOVES BACKWARDS ON IDLE AND DOES NOT STAY BETWEEN 0 - 800
THANKS
Dec 7, 2009 at 9:04 AM
DAVE H
  • CAR REPAIR CONTRIBUTOR
  • 13,384 POSTS
The idle is controlled by the cars computer using sensors and IAC (idle air control) valve and cannot be adjusted ..start by checking for any vacuum line leaks !
Dec 23, 2009 at 3:37 AM
AZMA
  • 11 POSTS
OK THANKS I WILL CHECK FOR ANY LEACKS ALONG THE. WHERE IS THE IAC VALVE LOCATED?
IS THERE AN ADJUSTMENT FOR RICH FUEL BURNING? THIS IS AGAIN IN THE PEUGEOT 206 XLINE
THANKS
Dec 23, 2009 at 4:59 AM
