2000 Peugeot 206 Overheating
2000 PEUGEOT 206
85,000 MILES • 6 CYL • FWD • MANUAL
JME2365
In september i had the head gasket and radiator replaced as the car was overheating.
This resolved the issue until last week where it started to overheat again.
I have taken it to the garage where the cooling system relays and wiring loom have been replaced but it is still over heating.
It is now due to have the colling fan replaced.
There was a pressure test done on the water pump not so long ago.
Do you know what could be causing the overheating as im not sure the cooling fan is the issue as it spins up when the air conditioning is turned on.
Thermostat was replaced when the head gasket was.
Thanks
Apr 30, 2009 at 9:20 PM
DAVE H
  • 13,384 POSTS
have the pump retested also have the cylinders compression tested or do a chemical test to check the headgasket was installed correctly !!
May 22, 2009 at 8:52 PM
