1999 Peugeot 206 oil mixed with water in radiator
RODMEC
1999 Peugeot 206 4 cyl
how to clean the radiator i.e remove old oil from the radiator (engine running ok as has been repaired)
Jun 26, 2009 at 8:58 AM
  • 31,937 POSTS
Hi there,
you can use a radiator flush, but oil in the cooling system will be hard to remove completely, often it is best to get the radiator professionally cleaned & flow tested.
mark (mhpautos)
Jun 27, 2009 at 3:02 AM
