1993 Peugeot 205 Possible Transmission Problem
1993 PEUGEOT 205
201,000 MILES • 6 CYL • FWD • MANUAL
CDIZK
Hey Everyone
Own a Peugeot 205SI with 200,000km on the clock.
The car has started to make an extremely loud, repetitive screeching noise when started. The noise seems to be less when the temperature is cold, but if the car has been driven then parked for around 30 mins, the start is fine.
I initially though that the problem was due to oil level, but I filled up with premium oil and replaced the filter, which only very slightly alleviated the problem, in terms of rate of occurrence, rather than severity.
Thanks for any help
Dec 23, 2009 at 8:16 PM
DAVE H
  • 13,384 POSTS
start by checking drive belt for wear/damage
Jan 24, 2010 at 9:05 PM
