1986 Peugeot 205 valve timing
1986 PEUGEOT 205
RALLYCROSS
Engine Mechanical problem
1986 Peugeot 205 4 cyl Two Wheel Drive Manual
when you put the 10mm dowel through the crank pulley, which of the three appertures on the block do you use for the dowel ? when changing a cam belt
Apr 23, 2010 at 5:39 AM
DAVE H
  • 13,384 POSTS
we do not have the spec's for this year vehicle .. your local autoparts store should be able to supply a repair manual with the details you need
May 30, 2010 at 11:36 PM
