2006 Peugeot 107 Fuel pump not working
BLAKEY
Engine Mechanical problem
2006 Peugeot 107 4 cyl Manual 16000 miles
Have purchased an accident damaged 107 and the fuel pump is not working, suspect fuel cut off switch has activated but I cannot locate the cut off switch or the relay. If I pour fuel direct, the engine starts so the engine is still working but the fuel is not getting through. Any advice appreciated. Thank you
Sep 4, 2008 at 10:20 PM
DAVE H
  • 13,383 POSTS
peugot vehicles are not fitted with a inertia fuel cut off switch .. check the fuse .. relay .. and pump and wiring ..
Mar 11, 2009 at 2:45 AM
