Engine Mechanical problem
2006 Peugeot 107 4 cyl Manual 16000 miles
Have purchased an accident damaged 107 and the fuel pump is not working, suspect fuel cut off switch has activated but I cannot locate the cut off switch or the relay. If I pour fuel direct, the engine starts so the engine is still working but the fuel is not getting through. Any advice appreciated. Thank you
Sep 5, 2008 at 5:20 AM
