2000 Peugeot 106 fuel problem
90 MILES • 4 CYL • FWD • MANUAL
SPIDER_MAN_NAD
hi i have a 106 quicksilver 1.4 that dose not start as it dose not pump fuel.have tryed new fuel pump and pressing the red button.but if i put positave nd negative to the fuel pump it dose pump fuel and start. but then floods it
Mar 5, 2010 at 7:06 AM
DAVE H
  • 13,383 POSTS
check fuel pump fuse and relay .. the computer (PCM)controls fuel pump "on" time .. check you are getting a hot/live feed to pump when cranking using a voltmeter .. if the pump is good, fuse is good, relay is good, then you have a fault on the wiring or a bad computer
Mar 30, 2010 at 8:00 PM
