1996 Peugeot 106 starting intermittently
98,000 MILES • 4 CYL • 2WD • MANUAL
0197NICK
Hi my car will not start on the key it turns over fine but no spark and no fuel to the carb? however it will bump off? iv alredy checked fuel pump which is working fine also new coil pack new carb and bypassed the ingnition il fresh out of ideas? after the car has been bump started and run for half hour or so it will start on the key! confused.com any ideas?? many thanks nick
Jun 10, 2010 at 6:34 AM
DAVE H
  • 13,383 POSTS
Hello. thanks for the donation .. much appreciated You must have a bad/loose ground/earth wire or power wire somewhere ? .. if you have no spark or fuel going to the cylinders it should not start even when jumping/bumping ?
https://images.2carpros.com/forum/automotive_pictures/266999_266999_smiley5_8_3.png
Jun 15, 2010 at 9:37 PM
