1992 Peugeot 106 Fuel pump, fuel relay, carburetor, idle pu
1992 PEUGEOT 106
100,000 MILES • 4 CYL • FWD • MANUAL
VALTER
The motor just stops without any warning. Starting again does not help. Start motor and the battery are ok. The problem is in electric fuel system. (1,1 l petrol motor). Does'nt get fuel. The pump in fuel tank is ok, but there is no voltage when you turn the switch on. The relay under the ECU has been changed.
The fault has occurred several times at last years. It dissappears by itself, doesn't matter if it's in own garage or by specialist. They guess and put a new part but don't find the actual fault because the situation is ower.
Jul 15, 2010 at 12:03 PM
DAVE H
  • 13,384 POSTS
check for a bad wire/connector to fuel pump
Jul 20, 2010 at 4:25 AM
EDDIE KID 46
Hi i have a 1992 peugeot 106 sometimes it will start but if i put some spray in the top of the carb it will start any suggestions thanks.
Oct 5, 2012 at 8:24 PM
