Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Ikon
Fuel System
Fuel Pump
petrol pump
2004 FORD IKON
125,000 MILES
ERICK LEPOTA
MEMBER
1 POST
fixing the pump.
Aug 18, 2017 at 7:12 AM
STEVE W.
Experienced Mechanic
If you mean replacing it, the pump is located inside the fuel tank and you have to remove the tank to remove and replace it.
Has it been tested to verify it is the pump and not a bad fuse or pump relay?
Aug 18, 2017 at 4:03 PM
Add image or video
Ask a new question
Engine won't start
Engine has low power
