Since given this car three years ago, there has been this ratcheting, dragging sort of noise coming from inside the driver side front wheel. Had brake pads, rotors, and right front axle replaced eighteen months ago-with no effect on this noise. Have now been told by a mechanic that the left axle, and the brake pads need replacing, and that it is this axle problem that affected my newish brake pads, and, most significantly, is causing the noise that I have described. Yet, how can this be when I have been hearing this noise before getting new brakes and the new axle, and the actions had no effect on this noise. Do not hear the clicking, upon turning, nor do I perceive any vibrating, shaking or shuddering. Only if I go over seventy five mph, there is some mild shuddering. This noise begins as soon as I start driving forward and continues until I reach about forty mph, or above, at which point it completely stops, until I slow down again. The noise occurs during turning and when driving straight. Recently, I have noticed it seems louder, and also now has a sort of echoing, it hollow quality to it. Any thoughts on this? Would be so very grateful to hear them.
Oct 11, 2017 at 8:07 AM
